Missing info in Zabbix installation instructions.
  • Shaul
    • Dec 2022
    I'm trying to work with official Zabbix installation instructions yet it looks like few or several key info items are missing ?
    for example , if working with install instructions seem like missing or there is nothing about data base installation needed on actual install steps , see for example step Forum
    after choosing platform on step Home , attempting to work on step Forum - Install and configure Zabbix for your platform , no info about any data base needed before getting to step #2b - Create initial database
    so , how should one guess or know that data base (MySql , MariaDB , etc'...) need to be installed separately and manually , as its not being done during the instructions steps.
    appreciate your help.
    • 4972
    How about reading those instructions? https://www.zabbix.com/documentation...uired-software
    • Shaul
      • Dec 2022
      Thanks for the info.
      • Shaul
        • Dec 2022
        BTY , can you advise where can I find info about how to configure monitoring ? add graphs , for example ?
          • 4972
          You really should start reading manual... and understand it...
          • Shaul
            • Dec 2022
            Thank you.
