specifying an interface to use for an item?
  • Abzstrak
    • Dec 2022
    • 9
    I have hosts with more than one snmp interface configured, but it only uses the default... is there a way to make an item use a specific interface, like if2?
    • 4996
    In template - no. But if template is already added to host, then on host level you can configure, which IF to use.
    • Abzstrak
      • Dec 2022
      • 9
      So these two interfaces are found in LLD, and i can't seem to change the interface on them after discovery. These are not consistent OIDs either but can change slightly per device making it hard to add manually the 9 items per interface.
