Top hosts - disk space on different partition
  • andy.brown
    • Apr 2019
    Hi everybody,
    I have two items on different servers to check on disk space.
    On the first server I'll check the partition /mnt/hd2 with the key "vfs.fs.size[/mnt/hd2,free]"
    On the secondo server the key is "vfs.fs.size[/media/hd2,free]"
    The two items have the same name "Free disk space"
    In the "top hosts" widget I see only one of them, even if in the "Data Overview" the data were correctly visible. I need to have different item for different partition or there is a way to show the data under the same column?
    Thanks!
    • 4996
    You can avoid it with changing the name of item, adding a mountpoint name to or something. I think I submitted a ticket about it to Zabbix. We agreed, that tehre is a small bug, but it has a workarlund.. they do not have any idea, when it might be fixed...
    In general it is a good idea to not have multiple items with same name.. But it is a little bug, as items with same name are allowed and they should be visible in widget also...​
