Calculated item on template to sum up LLD Item prototype values of the same host.
  • verde
    • Jul 2021
    • 39
    Hi, how to tweak a calculated item formula to achieve the following? I have a template that includes LLD item prototypes currently working on Zabbix 6.2.6.
    On the hosts using the template I would like to sum values from their own LLD item prototypes, so I created a new calculated item as part of the template (not prototype), but it's not working yet.
    I've changed the formula with small variations but none worked. Thanks
    Template calculated item. Formulas tried:
    sum(last_foreach(//prefixKey[*]))
    sum(last_foreach(/{HOST.HOST}/prefixKey[*]))
    Click image for larger version  Name:	2022-12-29_12-12.png Views:	0 Size:	20.2 KB ID:	456780
    Item prototype:
    Discovery rule macros: {#ITEMVAR} {#ITEMNUM}
    Click image for larger version  Name:	2022-12-29_12-11.png Views:	0 Size:	35.8 KB ID:	456781​
  • verde
    • Jul 2021
    • 39
    Nobody gave insights, but I figured it out.
    It's not documented but the calculated formula should follow the same "format" as the key being looked for. On my case, the LLD Key is "prefixKey[{#ITEMVAR},{#ITEMNUM}]", so the calculated formula that worked was: " sum( last_foreach(//prefixKey[*,*]) ) "
    Regards
    • dennistm
      • Jul 2023
      Thanks for posting this. Helped me with something similar without having to go through the zabbix documentation
      Cheers!
      • DanielG
        • Nov 2024
        For Zabbix 7
        item prototype: (Numeric): net.if.criticality.error.[{#SNMPINDEX}]
        Item: sum(last_foreach(//net.if.criticality.error.[*]))
        Regards
