Help with Zabbix after Ubuntu auto upgrade MYSQL
  • anderklein
    • Apr 2021
    Hello, my zabbix 5.2.1 is operating normally, but my Ubuntu automatically updated the Mysql database and after that I have a warning on the Dashboard saying:
    Incorrect default charset for Zabbix database: "utf8mb3" instead "UTF8".
    Surely this happened because something changed in the Mysql version, I did a short google search and didn't find anything concrete about this problem, is there an easy way to solve this problem and this warning disappears from zabbix?
    • 4996
    https://www.zabbix.com/documentation...all/db_scripts
    MySQL
    Character sets utf8 (aka utf8mb3) and utf8mb4 are supported (with utf8_bin and utf8mb4_bin collation respectively) for Zabbix server/proxy to work properly with MySQL database. It is recommended to use utf8mb4 for new installations.
    I am pretty sure you can find something about collation and changing it in forum...
    • Markku
      • Sep 2018
      • 1784
      https://www.zabbix.com/documentation...all/db_scripts (Zabbix 5.2 database information page) says:
      Character set utf8 and utf8_bin collation is required for Zabbix server/proxy to work properly with MySQL database.
      I would recommend upgrading from that old unsupported Zabbix version to 6.0.12 or 6.2.6. Make good backups, and you can try the new Zabbix versions with a copy of the current database.
      Markku
