Zabbix will not start post 6.2.0 to 6.2.6 upgrade
  • discarn8
    • May 2018
    Thanks for your time. May I please get assistance with the following?
    I have automatic updates via Webmin enabled on my Ubuntu VM and it upgraded my Zabbix agent, frontend-php, nginx-conf, server-mysql and sql-scripts from 6.2.0 to 6.2.6. All was running fine until last night, when I rebooted my esxi which rebooted my Zabbix VM. Now, I am receiving an error in the zabbix_server.log:
    Initially, I was receiving:
    Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    ****** Enabled features ******
    SNMP monitoring: YES
    IPMI monitoring: YES
    Web monitoring: YES
    VMware monitoring: YES
    SMTP authentication: YES
    ODBC: YES
    SSH support: YES
    IPv6 support: YES
    TLS support: YES
    using configuration file: /etc/zabbix/zabbix_server.conf
    current database version (mandatory/optional): 06020000/06020006
    required mandatory version: 06020000
    optional patches were found
    starting automatic database upgrade
    • [Z3005] query failed: [1419] You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable) [create trigger hosts_name_upper_insert before insert on hosts for each row set new.name_upper=upper(new.name)]
    • database upgrade failed
    I stopped zabbix-server, mysql, rebooted and received:
    • [Z3001] connection to database 'zabbix_db' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
    • database is down: reconnecting in 10 seconds
    Zabbix-server, mysql are running
    $ sudo systemctl status zabbix-server mysql
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
    Active: activating (start) since Thu 2023-01-05 00:14:17 MST; 1s ago
    Cntrl PID: 2147 (zabbix_server)
    Tasks: 2 (limit: 8155)
    Memory: 2.8M
    CPU: 15ms
    CGroup: /system.slice/zabbix-server.service
    └─2147 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    Jan 05 00:14:17 zabbix6 systemd[1]: Starting Zabbix Server...
    ● mysql.service - MySQL Community Server
    Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
    Active: active (running) since Wed 2023-01-04 23:53:18 MST; 21min ago
    Process: 824 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
    Main PID: 938 (mysqld)
    Status: "Server is operational"
    Tasks: 45 (limit: 8155)
    Memory: 558.6M
    CPU: 11.024s
    CGroup: /system.slice/mysql.service
    └─938 /usr/sbin/mysqld
    Jan 04 23:53:16 zabbix6 systemd[1]: Starting MySQL Community Server...
    Jan 04 23:53:18 zabbix6 systemd[1]: Started MySQL Community Server.
    My zabbix_server.conf
    $ sudo grep -e DBName -eDBUser -eDBPassword /etc/zabbix/zabbix_server.conf | grep -v "#"
    DBName=zabbix_db
    DBUser=zabbix
    DBPassword=zabbixpass
    My zabbix.conf.php
    $ sudo cat /etc/zabbix/web/zabbix.conf.php | more
    <?php
    // Zabbix GUI configuration file.
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '0';
    $DB['DATABASE'] = 'zabbix_db';
    $DB['USER'] = 'zabbix';
    $DB['PASSWORD'] = 'zabbixpass';
    mysql errata:
    $ mysql -u zabbix -h localhost --database=zabbix_db -p zabbixpass
    Welcome to the MySQL monitor. Commands end with ; or \g.
    Your MySQL connection id is 640
    Server version: 8.0.31-0ubuntu0.22.04.1 (Ubuntu)
    Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
    mysql>
    mysql> SHOW DATABASES;
    | Database |
    | information_schema |
    | mysql |
    | performance_schema |
    | sys |
    | zabbix_db |
    mysql> SHOW GRANTS FOR CURRENT_USER;
    | Grants for zabbix@localhost |
    | GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, RELOAD, REFERENCES, ALTER ON *.* TO `zabbix`@`localhost` WITH GRANT OPTION |
    | GRANT ALL PRIVILEGES ON `zabbix_db`.* TO `zabbix`@`localhost` |
    mysql> SHOW VARIABLES LIKE '%plugin%';
    | Variable_name | Value |
    | default_authentication_plugin | caching_sha2_password |
    | plugin_dir | /usr/lib/mysql/plugin/ |
    | replication_optimize_for_static_plugin_config | OFF |
    mysql> SHOW CREATE USER 'zabbix'@'localhost';
    | CREATE USER for zabbix@localhost |
    | CREATE USER `zabbix`@`localhost` IDENTIFIED WITH 'caching_sha2_password' AS '$V$447$juPL^9_=x_\'20eq
    h}bLMbjI4ooA3h0nW8Cb2djNn6ZlWe/zK/8ItsMwTkxrW' REQUIRE NONE PASSWORD EXPIRE DEFAULT ACCOUNT UNLOCK PASSWORD HISTORY DEFAULT PASSWORD REUSE INTERVAL DEFAULT PASSWORD REQUIRE CURRENT DEFAULT |
    OS Info:
    $ cat /etc/*release*
    DISTRIB_ID=Ubuntu
    DISTRIB_RELEASE=22.04
    DISTRIB_CODENAME=jammy
    DISTRIB_DESCRIPTION="Ubuntu 22.04.1 LTS"
    PRETTY_NAME="Ubuntu 22.04.1 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.1 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy​
  • tim.mooney
    • Dec 2012
    • 1436
    • discarn8
      • May 2018
      Wow. Nice - you're good. "SET GLOBAL log_bin_trust_function_creators = 1;" did the trick. Thank you!
