zabbix_get timeout on some items
  • dignus
    • Jan 2005
    • 14
    I'm getting timeouts using zabbix_get on some items.
    Situation:
    Server: Zabbix proxy &zabbix_get installed on debian 11 (6.0.12-1-debian11)
    Client: zabbix agent2 installed on CentOS 7 (zabbix-agent2-6.0.12-release1.el7.x86_64)
    When I execute a zabbix_get for uptime for example, I receive immediate response:
    root@proxy:~# zabbix_get -s 10.29.55.103 -k system.uptime
    28144426
    Other items work fine as well. However, when I want to discover filesystems, I'm getting a timeout:
    root@proxy:~# zabbix_get -s 10.29.55.103 -k vfs.fs.discovery
    zabbix_get [3693099]: Timeout while executing operation
    However, on the client side I see the following in the agent logs:
    2023/01/12 13:12:16.904023 received passive check request: 'vfs.fs.discovery' from '10.29.55.6'
    2023/01/12 13:12:16.904108 [1] processing update request (1 requests)
    2023/01/12 13:12:16.904115 [1] registering new client
    2023/01/12 13:12:16.904169 [1] adding new request for key: 'vfs.fs.discovery'
    2023/01/12 13:12:16.904192 [1] created direct exporter task for plugin 'VfsFs' itemid:0 key 'vfs.fs.discovery'
    2023/01/12 13:12:16.904251 executing direct exporter task for key 'vfs.fs.discovery'
    2023/01/12 13:12:16.904503 executed direct exporter task for key 'vfs.fs.discovery'
    2023/01/12 13:12:16.904521 sending passive check response: '[{"{#FSNAME}":"/","{#FSTYPE}":"rootfs"},{"{#FSNAME}":"/sys","{#FSTYPE}":"sysfs"},{"{#FSNAME}":"/proc","{#FSTYPE}":"proc"},{"{#FSNAME}":"/dev","{#FSTYPE}":"devtmpfs"},{"{#FSNAME}":"/sys/kernel/security","{#FSTYPE}":"securityfs"},{"{#FSNAME}":"/dev/shm","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/dev/pts","{#FSTYPE}":"devpts"},{"{#FSNAME}":"/run","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/sys/fs/cgroup","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/sys/fs/cgroup/systemd","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/pstore","{#FSTYPE}":"pstore"},{"{#FSNAME}":"/sys/firmware/efi/efivars","{#FSTYPE}":"efivarfs"},{"{#FSNAME}":"/sys/fs/cgroup/blkio","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/memory","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/cpu,cpuacct","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/devices","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/cpuset","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/net_cls,net_prio","{#FSTYPE}":"cgroup"},{"{#FSNAME }":"/sys/fs/cgroup/freezer","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/pids","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/perf_event","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/hugetlb","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/kernel/config","{#FSTYPE}":"configfs"},{"{#FSNAME}":"/","{#FSTYPE}":"xfs"},{"{#FSNAME}":"/sys/kernel/debug","{#FSTYPE}":"debugfs"},{"{#FSNAME}":"/proc/sys/fs/binfmt_misc","{#FSTYPE}":"autofs"},{"{#FSNAME}":"/dev/mqueue","{#FSTYPE}":"mqueue"},{"{#FSNAME}":"/run/storpool/hugetlb","{#FSTYPE}":"hugetlbfs"},{"{#FSNAME}":"/dev/hugepages","{#FSTYPE}":"hugetlbfs"},{"{#FSNAME}":"/boot","{#FSTYPE}":"xfs"},{"{#FSNAME}":"/boot/efi","{#FSTYPE}":"vfat"},{"{#FSNAME}":"/run/user/0","{#FSTYPE}":"tmpfs"}]' to '10.29.55.6'
    Retrieving the same key locally on the client does give me the correct response:
    [root@client ~]# zabbix_agent2 -t vfs.fs.discovery
    vfs.fs.discovery [s|[{"{#FSNAME}":"/","{#FSTYPE}":"rootfs"},{"{#FSNAME}":"/sys","{#FSTYPE}":"sysfs"},{"{#FSNAME}":"/proc","{#FSTYPE}":"proc"},{"{#FSNAME}":"/dev","{#FSTYPE}":"devtmpfs"},{"{#FSNAME}":"/sys/kernel/security","{#FSTYPE}":"securityfs"},{"{#FSNAME}":"/dev/shm","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/dev/pts","{#FSTYPE}":"devpts"},{"{#FSNAME}":"/run","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/sys/fs/cgroup","{#FSTYPE}":"tmpfs"},{"{#FSNAME}":"/sys/fs/cgroup/systemd","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/pstore","{#FSTYPE}":"pstore"},{"{#FSNAME}":"/sys/firmware/efi/efivars","{#FSTYPE}":"efivarfs"},{"{#FSNAME}":"/sys/fs/cgroup/blkio","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/memory","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/cpu,cpuacct","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/devices","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/cpuset","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/net_cls,net_prio","{#FSTYPE}":"cgroup"},{"{#FSNAME }":"/sys/fs/cgroup/freezer","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/pids","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/perf_event","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/fs/cgroup/hugetlb","{#FSTYPE}":"cgroup"},{"{#FSNAME}":"/sys/kernel/config","{#FSTYPE}":"configfs"},{"{#FSNAME}":"/","{#FSTYPE}":"xfs"},{"{#FSNAME}":"/sys/kernel/debug","{#FSTYPE}":"debugfs"},{"{#FSNAME}":"/proc/sys/fs/binfmt_misc","{#FSTYPE}":"autofs"},{"{#FSNAME}":"/dev/mqueue","{#FSTYPE}":"mqueue"},{"{#FSNAME}":"/run/storpool/hugetlb","{#FSTYPE}":"hugetlbfs"},{"{#FSNAME}":"/dev/hugepages","{#FSTYPE}":"hugetlbfs"},{"{#FSNAME}":"/boot","{#FSTYPE}":"xfs"},{"{#FSNAME}":"/boot/efi","{#FSTYPE}":"vfat"},{"{#FSNAME}":"/run/user/0","{#FSTYPE}":"tmpfs"}]]​
    When stracing the zabbix_get command it's stuck here:
    socket(AF_INET, SOCK_STREAM|SOCK_CLOEXEC, IPPROTO_TCP) = 3
    fcntl(3, F_SETFD, FD_CLOEXEC) = 0
    alarm(30) = 0
    connect(3, {sa_family=AF_INET, sin_port=htons(10050), sin_addr=inet_addr("10.29.55.103")}, 16) = 0
    write(3, "ZBXD\1\20\0\0\0\0\0\0\0vfs.fs.discovery", 29) = 29
    read(3,
    Looks like the data the agent is sending back, never arrives at the server I run zabbix_get ​from.
    So... network communication seems OK, I can retrieve other items. The agent's output for this key is also good when executed from localhost. However.. not for fs discovery. Any ideas what's going wrong?
    Issue resolved: MTU misconfiguration in the path from 1 to the other machine.
  • Markku
    • Sep 2018
    • 1784
    Thanks for confirming, I would have suggested verifying the MTU
    Markku
