Zabbix V3.0.1 install with RPMs with Postgres 9.5
  • esawyja
    • Dec 2011
    • 54
    Hi all
    Trying to install Zabbix 3.0.1 on Centos 7, I get this error, where can I find the zabbix-web-database?
    [root@centos7 zabbix_install]# rpm -ivf zabbix-web-3.0.1-1.el7.noarch.rpm
    warning: zabbix-web-3.0.1-1.el7.noarch.rpm: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
    error: Failed dependencies:
    zabbix-web-database = 3.0.1-1.el7 is needed by zabbix-web-3.0.1-1.el7.noarch
    [root@centos7 zabbix_install]# rpm -ivf zabbix-web-pgsql-3.0.1-1.el7.noarch.rpm
    warning: zabbix-web-pgsql-3.0.1-1.el7.noarch.rpm: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
    zabbix-web = 3.0.1-1.el7 is needed by zabbix-web-pgsql-3.0.1-1.el7.noarch
    [root@centos7 zabbix_install]# rpm -qa | grep zabbix
    zabbix-release-3.0-1.el7.noarch
    zabbix-server-pgsql-3.0.1-1.el7.x86_64
    zabbix-agent-3.0.1-1.el7.x86_64
    zabbix-java-gateway-3.0.1-1.el7.x86_64
    Thanks!
  • Atsushi
    • Aug 2013
    • 2028
    Please try exec this command.
    # rpm -ivf zabbix-web-3.0.1-1.el7.noarch.rpm zabbix-web-pgsql-3.0.1-1.el7.noarch.rpm
    • esawyja
      • Dec 2011
      • 54
      WOW thank you!!
      [root@centos7 zabbix_install]# rpm -ivf zabbix-web-3.0.1-1.el7.noarch.rpm zabbix-web-pgsql-3.0.1-1.el7.noarch.rpm
      Preparing packages...
      Why would it work when both rpms are on the same line?
      • Atsushi
        • Aug 2013
        • 2028
        If the package has any dependencies, you will need to install at the same time.
        • esawyja
          • Dec 2011
          • 54
          Thanks again!
