Caclulated Item for Memory
  • vahab
    • Apr 2016
    Hi, I am using Zabbix 3.0.1 and trying to get the real memory usage in Zabbix and then make the graph.
    The value that I am interested in is : used - buffers - cached
    By using zabbix_get I see that zabbix has a value for each of those Items.
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[total]"
    12197720
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[free]"
    2889368
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[buffers]"
    36060
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[cached]"
    4338156
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[used]"
    9308352
    /usr/bin/zabbix_get -s <hostname> -k "vm.memory.size[available]"
    7263584
    When I define a 'Calculated' item for a host and put a formula it works fine for 'buffers' but gives me an error when I enter cached in the formula.
    This formula works without any error :
    Formula : last("vm.memory.size[buffers]")
    Type of Information : Numeric (unsigned)
    But when I change the formula as following it gives an error after a while
    Formula : last("vm.memory.size[cached]")
    Status : Not supported
    Info : Cannot evaluate expression : expected numeric token at "vm.memory.size[cached]"
    I am wondering what is different ,while both have numeric values and looks to have a value in Zabbix. Does anyone have an idea ?
    Thank you !
