Appliance not starting: Database error
  • Prokurator
    • Jan 2023
    Hi All,
    I am new to Zabbix.
    Today I downloaded the 6.2 appliance and was thinking that it would be running from scratch, as expected from an appliance, but unfortunately not. Frontend says "Database error. connection refused".
    In server log stays:
    1277:20230117:204244.798 [Z3001] connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
    1277:20230117:204244.798 database is down: reconnecting in 10 seconds
    MySQL service status:
    # systemctl status mysqld.service
    ● mysqld.service - MySQL 8.0 database server
    Loaded: loaded (/usr/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled)
    Drop-In: /etc/systemd/system/mysqld.service.d
    └─override.conf
    Active: failed (Result: exit-code) since Tue 2023-01-17 20:29:14 CET; 16min ago
    Process: 1248 ExecStopPost=/usr/libexec/mysql-wait-stop (code=exited, status=0/SUCCESS)
    Process: 1201 ExecStart=/usr/libexec/mysqld --basedir=/usr (code=exited, status=1/FAILURE)
    Process: 1157 ExecStartPre=/usr/libexec/mysql-prepare-db-dir mysqld.service (code=exited, status=0/SUCCESS)
    Process: 1089 ExecStartPre=/usr/libexec/mysql-check-socket (code=exited, status=0/SUCCESS)
    Main PID: 1201 (code=exited, status=1/FAILURE)
    Status: "Server shutdown complete"
    Jan 17 20:29:12 appliance systemd[1]: Starting MySQL 8.0 database server...
    Jan 17 20:29:12 appliance mysql-check-socket[1089]: Socket file /var/lib/mysql/mysql.sock exists.
    Jan 17 20:29:12 appliance mysql-check-socket[1089]: No process is using /var/lib/mysql/mysql.sock, which means it is a garbage, so it will be removed automatically.
    Jan 17 20:29:14 appliance systemd[1]: mysqld.service: Main process exited, code=exited, status=1/FAILURE
    Jan 17 20:29:14 appliance systemd[1]: mysqld.service: Failed with result 'exit-code'.
    Jan 17 20:29:14 appliance systemd[1]: Failed to start MySQL 8.0 database server.
    How can I get it running?
  • LenR
    • Sep 2009
    • 1011
    It looks like mysql server is failing to start. I tested the .ovf version today and it works OK. What flavor are you using?
    • Prokurator
      • Jan 2023
      I am using VMware (.vmx).
      If I start MySQL manually it fails:
      # systemctl start mysqld.service
      Job for mysqld.service failed because the control process exited with error code.
      See "systemctl status mysqld.service" and "journalctl -xe" for details.
      Status message is in the first post. Do you know how to get it started?
      Meanwhile, I will try the .ovf version.​
      • Prokurator
        • Jan 2023
        The .ovf version is working from scratch. It seems to be something wrong with the VMware one.
        • pyritejoe
          • Aug 2022
          • 15
          I have had this issue a couple times and ended up doing a uninstall and reinstall of the mysql. Just backup the database folder, uninstall msql, remove the mysql folders, reinstall. Do the initial setup of mysql and then stop is and copy over the zabbix folder ytou backed up and start mysql trhen zabbix.
          • mouataz
            mouataz commented
            Can you please share with me how to do this process ! my school-project stop because of this issue please
        • mouataz
          • May 2024
