Some items not updating within the set Interval
  • admclip
    • Jan 2023
    I've added a Cisco ASA as a host, monitored by a proxy, with the default Cisco ASAv by SNMP template that comes with Zabbix.
    But some discovered items (interfaces) are not being updated within the set interval, see output below.
    The items, Administrative- and Operational status as well as description, name and link speed are not being updated after 1 minute. This may be happening to other items as well.
    Where should I start looking?
    Nothing unusual found in the server or proxy log and nothing in the queue either.
  • Answer selected by admclip at 01-02-2023, 16:09.
    admclip
    • Jan 2023
    Issue has been solved but I needed to wait to get my post approved.
    There is a Processing rule in place.....after deleting it the items got updated. I understand that this is in place for a description for example, but not for a operational status of a interface.
    • markosa
      • Aug 2022
      • 107
      You changed polling interval to template? If so, have you waited long enough that configuration is populated to proxy + discovery has found those interfaces again?
      • admclip
        • Jan 2023
