Zabbix Server and NAT
  • Rattlehead.ie
    • Jan 2023
    Hi guys,
    New to Zabbix, so learnng as I go. Im running into an issue, even before I start adding monitored hosts.
    Scenario:
    When I setup the Zabbix Server I was on lets call it Subnet A (this subnet is on a DMZ subnet behind a DMZ firewall, with other Corp Subnets infront of the firewall), I when setting this up had direct access to the server via sitting on Subnet A. This is all well and good. I can access it via the IP and the NS name if it resolves to the IP address of the server that zabbix sits on.
    However, I want to access this dahsboard/zabbix server now from Subet B, this subnet being a Corporate subnet infront of the DMZ firewall.
    Troubleshooting:
    When I try and access the server, I can get to the server, I see the access.log within nginx serve me, however the url either by IP or NS is unavaialble (nginx response). I can change the /etc/zabbinx/nginx.conf to listen to the name it should resolve too, that gets me to at least a login page, but it doesnt present the CSS/Formatting is allwrong.
    Is there a way to have the server respond to any request on port 80 rather than having to specifiy the NS or the real IP of the server, can I use the outside NAT IP.
    Thanks in advance
    Rattle
