Confused about setting up ESX host monitoring
  • BlueKnight
    • Jan 2023
    From the guide I see the following instructions:
    Setup
    1. Compile zabbix server with required options (--with-libxml2 and --with-libcurl)
    2. Set the StartVMwareCollectors option in Zabbix server configuration file to 1 or more
    3. Create a new host
    4. Set the host macros (on host or template level) required for VMware authentication:
    When creating the new host, an interface type needs to be selected. Normally I run Zabbix Agents on everything. Am I supposed to be installing an agent on the ESX hosts/vSphere server? ​
  • LenR
    • Sep 2009
    • 1011
    Not for these instructions. This host is used for VMware discovery, it is the URL to "vCenter". It will then find the hosts and VM's.
