Problem Alert (C:): Space utilization
  • sic61
    • Jan 2023
    We have an issue with the Space utilization trigger for a server.
    This one exceeds 90% occupancy. The information is well reported by Zabbix but this one does not appear as URGENT and the value Mounted filesystem discovery: (C: Disk space is critically low remains at OK instead of PROBLEM
    For other servers it works fine.
  • Rachelfoster
    • Jul 2022
    • 11
    I just want to say the issue may be with the configuration of the trigger for this specific server in Zabbix. The trigger for the "Mounted filesystem discovery: (C: Disk space is critically low" may not be properly configured to recognize when the server's space utilization exceeds 90% and change its status to "PROBLEM." It may also be helpful to check if the item's update interval is correct and is not missing any updates, also check the item's key is correct and if the item is linked to the trigger. It may be necessary to adjust the trigger's settings or to consult the Zabbix documentation for troubleshooting assistance. PartyCityFeedback
