Triggers not clearing properly
  • markosa
    • Aug 2022
    • 107
    I have following problem with triggers, those are triggering well but when there's recovery action it won't work that well. Trigger has this kind of config:
    trigsourcedev tag gets unique value from incoming data as does trigger itself(name field), so I do get different alerts with unique trigsourcedev tags from this specific trap(well it's zabbix trapper item which gets its data from incoming snmp traps via custom snmptrap listener).
    Now, when I get values for this item, trigger fires and creates n-alerts, but when theres recovery situation only one alert get cleared and others stay active even when there's matching recovery occuring those too.
    Should recovery work like this or is there a bug this area? Any ideas?
    Zabbix 6.0.12, mysql, zabbix-proxy ​
  • markosa
    • Aug 2022
    • 107
    Hmmnnn, looks like [ZBX-14313] Triggers with "All problems if tag values match" option do not work - ZABBIX SUPPORT​ has returned...
      • 4996
      In that ticket all got closed instead of one, even the ones where tags don't match.. yours seem bit different.. only one closes, even if there is more matches...
      • markosa
        • Aug 2022
        • 107
        Yes, now it behaves bit differently, there was also other issue linked to that. Anyway I created [ZBX-22269] Triggers with "All problems if tag values match" option do not work - ZABBIX SUPPORT​
        • slavomir.mladek
          • Sep 2023
          same problem here
