Couldn't resolve host name: getaddrinfo() thread failed to start
  • Mark P Thornton
    • Feb 2022
    • 10
    I am getting this error in a web step run from a Zabbix Proxy running in a docker container.
    Proxy version is 6.0.12 SQLite3 version.
    The same image is running without problems in another Docker Swarm.
    Any ideas?
    Mark Thornton
  • Rachelfoster
    • Jul 2022
    • 11
    Hello, here It's difficult to provide a specific solution without more information about the error and the context in which it is occurring. However, here are a few things that you can try to troubleshoot the issue:
    1. Check the log files of the Zabbix proxy container for any error messages that may provide more information about the cause of the problem.
    2. Make sure that the SQLite3 version in the proxy container is compatible with the version of the Zabbix proxy software.
    3. Check the configuration of the proxy container and compare it with the configuration of the other container that is running without problems. Look for any differences in environment variables, volumes, and network settings that may be causing the issue.
    4. Check the resource allocation of the container, such as CPU and memory, to ensure that the container is not running out of resources.
    5. Make sure that the container has proper permissions to access the necessary files, folders and network ports.
    6. Compare the version of the container image between the containers, check that the image versions are the same.
    If none of these suggestions help, you may want to seek help from the Zabbix community or the Docker community for additional troubleshooting and support.
    • Mark P Thornton
      • Feb 2022
      • 10
      The host environment is Ubuntu 18.04.3
      ​The environment where it works is Ubuntu 18.04.6
      Docker version is 19.03.2
      ​and where it works is 20.10.17
      The image was zabbix/zabbix-proxy-sqlite3:ubuntu-6.0-latest
      from the official repository on github with mysql client and some scripts added in /usr/lib/zabbix/externalscripts
      Nothing unusual in the zabbix proxy logs. No resources issues that I could find.
      Regards,
      Mark
      • Mark P Thornton
        • Feb 2022
        • 10
        The docker container image is exactly the same on both systems. Proxy configuration only differs in proxy name.
        Mark​
        • Markku
          • Sep 2018
          • 1784
          How is name resolution configured on both of those systems? Can you try manually resolving the affected hostname (from the web step) from the container?
          Markku
          • Mark P Thornton
            • Feb 2022
            • 10
            None of curl, nslookup or dig manage to resolve anything from inside the container - can't reach a DNS server. Something to investigate. And yet the container managed to resolve the address of the zabbix server. Rather odd.
            Note I had to use nsenter to run those commands as most containers don't include any useful networking tools :-(.
            Mark
            • Mark P Thornton
              • Feb 2022
              • 10
              nslookup and dig both work if given the address of the nameserver found in /etc/resolv.conf within the container (127.0.0.11).
              Mark
              • Mark P Thornton
                • Feb 2022
                • 10
                On the working environment dig and nslookup both work without the need to specify the server address.
                Mark
                • Markku
                  • Sep 2018
                  • 1784
                  Unfortunately I'm unable to give any direct advice how to fix the name resolution in container platform, but maybe you can find out somewhere else if that is a known problem in some cases, or if the newer Docker version has fixed something about it.
                  Markku
                  • Mark P Thornton
                    • Feb 2022
                    • 10
                    Upgrading docker to 20.10.23 fixed the problem with the container, though dig and nslookup still don't resolve within the container unless the server is specified.
                    Unfortunately DNS issues with Docker seem to be legion, with extra variants for Swarm and docker-compose.
                    Thanks for your help Markku.
                    Mark
