Zabbix appliance server 6.0.7 dont start after minor upgrade to 6.0.12
  • Rudlafik
    • Nov 2018
    • 168
    3345:20230131:105550.704 using configuration file: /etc/zabbix/zabbix_server.conf
    3345:20230131:105550.715 current database version (mandatory/optional): 06000000/06000010
    3345:20230131:105550.715 required mandatory version: 06000000
    3345:20230131:105550.715 optional patches were found
    3345:20230131:105550.715 starting automatic database upgrade
    3345:20230131:105550.716 [Z3005] query failed: [1419] You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable) [create trigger hosts_name_upper_insert
    The solution is this procedure:
    systemctl stop zabbix-server
    systemctl stop mysqld​
    Add log_bin_trust_function_creators = 1 to zabbix.cnf under /etc/my.cnf.d
    systemctl start mysqld
    systemctl start zabbix-server​
    Wait till the upgrade is completed:
    tail -999f /var/log/zabbix/zabbix_server.log​
    (systemctl restart zabbix-server)
