MySQL Slave metrics from plugin Zabbix_agent2
  • nexus-256
    • Jan 2023
    Good afternoon!
    I use the MySQL plugin for Zabbix_agent 2.
    This plugin works perfectly, it has all the necessary metrics, it is very easy and convenient to configure connections through sessions in the configuration file.
    However, I am having problems with replication metrics:
    1. If there is more than one replication channel, the key "mysql.replication.get_slave_status" returns the values of only the first channel.
    I have several replication channels, so unfortunately I can't use the plugin to monitor them...
    2. I would really like to be able to get not only the Master_Host value, but also the Channel_Name value in the "mysql.replication.discovery" method, because several replication channels can be connected from one master and their metrics will be difficult to distinguish.
    Please let me know if there is an opportunity to fix this?
    Version zabbix_agent2 6.0.12​
    • 4996
    Sounds like feature request... you should submit it here https://support.zabbix.com/projects/ZBXNEXT/issues
