zabbix proxy ODBC freetds MSSQLServer-Adaptive Server is unavailable or does not exis
  • dde.silva
    • Feb 2023
    I have a zabbix proxy dedicated to run queries on mssql server.
    In the proxy (vm rocky linux) I installed unixODBC and freetds.
    However, the item created on the same server of zabbix-proxy to execute the query is showing this error:
    Cannot connect to ODBC DSN: [SQL_ERROR]:[08S01][20009][[unixODBC][FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist]|[08S01][20009][[unixODBC ][FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist]|[08001][0][[unixODBC][FreeTDS][SQL Server]Unable to connect to data source]
    When connecting to the database through the server using isql the connection is successful and its possible to run queries:
    isql ABC user password
    | Connected! |
    | sql-statement |
    | help [tablename] |
    | quit |
    When I run zabbix_get is showing this msg:
    ZBX_NOTSUPPORTED: Unsupported item key.
    >> /etc/odbcinst.ini
    [FreeTDS]
    Description = Free Sybase & MS SQL Driver
    Driver = /usr/lib64/libtdsodbc.so.0
    Trace = Yes
    TraceFile = /tmp/freetds.log
    >> /etc/odbc.ini
    [ABC]
    Driver = FreeTDS
    Description = Database Monitor ABC
    Server = 172.xx.xx.xx
    Port = 1433
    TDS_Version = 8.0
    Database = ABC​
    >> Item zabbix
    There is no error record in the server logs.
    Zabbix Server: 6.0 on docker
    Grateful if you can help me to solve the problem.​
  • danterpaniagua
    • Jan 2024
    Hello, i have the same problem. You can solve it?
