Support Log Discovery or Aggregation
  • emerzon
    • Apr 2008
    • 21
    Hello all,
    I want to monitor some application which writes their logs in this format:
    C:\Program Files\Application\InstanceX\logs\yyddmm.log
    The problem I have is that each machine has an arbitraty number of instances, therefore a different number of logs to be monitored.
    My first attempt to work around that was using logrt.count with a regex like:
    C:\\Program Files\\Application\\Instance.*log
    However, this doesn't work it seems that the regex part can only be applied to the base filename, not the path itself.
    So I went with a bruteforce approach, and created individual items for the each possible instances I could have in one machine.
    That sorta of works, but leaves a lot of unsupported items in the machines that have less than maximum total instances.
    The next step was to aggregate the counts I can know how many occurences of count happened on a given machine, regardless of how many instances that machine has.
    Again I went with a bruteforce approach by creating a calculated item like
    last(//logrt.count[C:\Program Files\Application\Instance1\logs\yyddmm.log,.*string])+last(//logrt.count[C:\Program Files\Application\Instance2\logs\yyddmm.log,.*string])​+[...]
    For all instances.
    That worked for the instances with the maximum number of instances, but fails for the others. I know this is overall a terrible approach, but I wasnt able to find a different one.
    Can anyone point me to the right approach for this case?
    I was imagining using something like Log Discovery, but I am not sure if this is even possible.
    • 4996
    There is no built-in log discovery. You probably need to build one by yourself, define it as UserParameter and use its output for discovery, which will create all your logfile items.
    • Hamardaban
      • May 2019
      • 2714
      I think the following way will be correct: using the key vfs.dir.get​ you create a LLD rule that finds you all existing directories InstanceX.
      Then, based on what you find, you create logrt() you need from the prototypes.
        • 4996
        Oh, right.. That would solve things without any additional stuff...
        I am still not used to those new(ish) vfs.* items..:P
