Zabbix6.2.7 Source install problem
  • Autumner
    • Jun 2022
    Use source code install Zabbix 6.2.7
    php version
    Nginx version
    ​problem​:
    nging logs
    ​2023/02/08 16:10:35 [error] 181688#0: *1 FastCGI sent in stderr: "PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/nginx/html/include/classes/core/CCookieSession.php on line 194" while reading response header from upstream, client: 172.16.1.1, server: localhost, request: "GET /setup.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "172.16.1.50"
  • tim.mooney
    • Dec 2012
    • 1437
    Read the "Requirements" section of the documentation, for the "Frontend": https://www.zabbix.com/documentation...n/requirements
    PHP 8.2 isn't supported until version 6.2.8. The version you're using only supports PHP 7.4, 8.0, and 8.1.
    • Melissa25
      • Feb 2023
      Here are some general steps you can follow to troubleshoot:
      1. Ensure that your system meets the requirements for running Zabbix 6.2.7, including the required software dependencies.
      2. Verify that you have downloaded the correct version of the Zabbix source code and extracted it to the appropriate location on your system.
      3. Check the Zabbix documentation or release notes for any known issues or workarounds related to your specific installation scenario.
      4. Review any error messages or log files generated during the installation process to identify any specific issues that may be preventing a successful installation.
      5. Search online forums or other resources for other users who may have encountered similar issues during their Zabbix installations and follow any recommended solutions that are relevant to your situation.
      ​If you can provide more specific information about the error you are encountering, I may be able to provide more targeted advice.
      KanTime Medicare Login
