Get Problems through Zabbix API, but unable to link them to Hosts
  • bganichaud
    • Feb 2023
    I would like to use API to get information problems from zabbix.
    I can get problem list, and also host list, but I don't know how to link problems to hosts.
    Do you know il I can use API methods to do the relation between those 2 information?
    Thank you.
    Regards.
  • LenR
    • Sep 2009
    • 1011
    Just looking at the API reference, I haven't tested: The problem has object and objectid fields, using triggers for the object (value is 0) then the object id is a trigger, so you would use it in trigger.get. Add selectItems to the trigger get so you don't have to parse the expression. The item(s) will include a hostid field of the related host.
    Looking at things like this makes us appreciate just how responsive the frontend is with all this in the background :-)
