Zabbix 5.4 > 6.0 mysql database upgrade error
  • garryavx
    • Feb 2022
    ...so it's working fine in the GUI after the upgrade but I get this spam in the log:
    27791:20230213:220845.879 database upgrade failed
     27791:20230213:220845.882 database could be upgraded to use primary keys in history tables
     27795:20230213:220858.107 Starting Zabbix Server. Zabbix 6.0.13 (revision fdfa8cef9ce).
     27795:20230213:220858.108 ****** Enabled features ******
     27795:20230213:220858.108 SNMP monitoring:           YES
     27795:20230213:220858.108 IPMI monitoring:           YES
     27795:20230213:220858.108 Web monitoring:            YES
     27795:20230213:220858.108 VMware monitoring:         YES
     27795:20230213:220858.108 SMTP authentication:       YES
     27795:20230213:220858.108 ODBC:                      YES
     27795:20230213:220858.108 SSH support:               YES
     27795:20230213:220858.108 IPv6 support:              YES
     27795:20230213:220858.108 TLS support:               YES
     27795:20230213:220858.108 ******************************
     27795:20230213:220858.108 using configuration file: /etc/zabbix/zabbix_server.conf
     27795:20230213:220858.125 current database version (mandatory/optional): 06000000/06000010
     27795:20230213:220858.125 required mandatory version: 06000000
     27795:20230213:220858.125 optional patches were found
     27795:20230213:220858.125 starting automatic database upgrade
     27795:20230213:220858.126 [Z3005] query failed: [1419] You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable) [create trigger hosts_name_upper_insert
    before insert on hosts for each row
    set new.name_upper=upper(new.name)]
     27795:20230213:220858.126 database upgrade failed
     27795:20230213:220858.129 database could be upgraded to use primary keys in history tables​
    not sure what to make of it since the front end seems blissfully unaware of any problems.
    on centos stream 8, mysql + nginx zabbix_server install
    what other info can I give to help?
  • garryavx
    • Feb 2022
    oh, JK I get this message on the GUI, so yeah it's borked then.
    • garryavx
      • Feb 2022
      nvm found a post on this forum about a similiar issue:
      followed the steps to set the flag:
      I've just had the same issue with MySQL 8.0.29.
      For future reference, this is what I did.
      When checking the database, I found "log_bin_trust_function_creators" was set to "Off".
      mysql> SHOW VARIABLES LIKE 'log_bin_trust_function_creators'; +---------------------------------+-------+ | Variable_name | Value | +---------------------------------+-------+ | log_bin_trust_function_creators | OFF | +---------------------------------+-------+
      Therefore, as suggested by Atsushi , we can simply set it to "On" (1).
      mysql> SET GLOBAL log_bin_trust_function_creators = 1;
      T​
