PagerDuty Integration Media type test fails
  • EmilyV
    • Feb 2023
    I'm running Zabbix 5.0.21 and trying to send test alarms to PagerDuty. I get Media type test failed. PagerDuty notification failed: Error: cannot get URL: SSL connect error.
    I've reached out to PagerDuty but they don't see anything wrong. Can someone please help point me in the right direction?
    I am wondering if I need some sort of certificate on my Zabbix server to allow communication with PagerDuty?
    OpenSSL is also failing:
    write:errno=104
    no peer certificate available
    No client certificate CA names sent
    SSL handshake has read 0 bytes and written 311 bytes
    New, (NONE), Cipher is (NONE)
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    SSL-Session:
    Protocol : TLSv1.2
    Cipher : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg : None
    Krb5 Principal: None
    PSK identity: None
    PSK identity hint: None
    Start Time: 1676306225
    Timeout : 300 (sec)
    Verify return code: 0 (ok)
