SSL Certificate file
  • aidaitzabbix
    • Jan 2023
    • 12
    I'm trying to monitor some websites inside my firewall.
    I set up the authentication tab in web scenario as following:
    I got the following error ​: Step "Site availability" [1 of 1] failed: Problem with the local SSL certificate: could not load PEM client certificate, OpenSSL error error:80000002:system library::No such file or directory, (no key found, wrong pass phrase, or wrong file format?)
    My cert and key are located in the following paths:
    /etc/ssl/private/ --> for the key
    /etc/ssl/certs/ --> for the cert
    How can I fix the problem?.
    Thanks in advance.​
  • H3lL_YeaH
    • Jun 2023
    Try
    SSLCertLocation "/usr/share/zabbix/ssl/certs"
    SSLKeyLocation "/usr/share/zabbix/ssl/keys"
    • olivierd
      • Jun 2024
      I've got the same error wheras my cert and key are in the apropriate folder.
      The strange thing is that when I click on the item and click "Test" I've got an answer with the expected value and no error, but on the items page, the item's got the status "Not supported" and the red square with an i in the info column.
      I've got this problem since I've upgraded to Zabbix 7.0 both server and agent.
      And I think that there's something with TLSv1.3 : I think Zabbix server run the hgttp request with TLS1.2 but it's openssl v3 and thus TLSv1.3 that should be used.
