Problem restarting Zabbix proxies
  • slinuxadm
    • Feb 2023
    Hello everyone,
    We are running zabbix_server (Zabbix) 6.2.6 with 4 proxies (zabbix_proxy (Zabbix) 6.2.6) on Red Hat Enterprise Linux 8.7 (Ootpa).
    I attempted to restart the proxies with systemctl restart zabbix-proxy and systemctl status zabbix-proxy now shows:
    zabbix-proxy.service - Zabbix Proxy
    Loaded: loaded (/usr/lib/systemd/system/zabbix-proxy.service; enabled; vendor preset: disabled)
    Active: deactivating (stop-sigterm) (Result: exit-code) since Thu 2023-02-16 08:36:15 CET; 48min ago
    Process: 1961 ExecStart=/usr/sbin/zabbix_proxy -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 1963 (code=exited, status=1/FAILURE)
    Tasks: 1141 (limit: 823018)
    The only entries in /var/log/zabbix/zabbix_proxy.log, prior to and since attempting the restart and other than those similar to:
    1986:20230216:091858.700 received configuration data from server at "xx.xxx.xx.xx", datalen 19160595
    are:
    2003:20230216:083615.030 executing housekeeper
    2003:20230216:083617.865 housekeeper [deleted 736654 records in 2.828684 sec, idle for 1 hour(s)]
    ps -aef | egrep '[1]963' shows:
    zabbix 2373 1 0 08:36 ? 00:00:02 /usr/sbin/zabbix_proxy: poller Services [got 3 values in 1.021963 sec, getting values]
    ps -aef | egrep '[1]961' shows nothing
    This problem exists on all four proxies.
    Any help is appreciated.
    Thanks!​
  • slinuxadm
    • Feb 2023
    UPDATE
    Starting the zabbix proxy with systemctl start zabbix-proxy does not create the PID file in /run/zabbix as expected, according to: /usr/lib/systemd/system/zabbix-proxy.service
    [Unit]
    Description=Zabbix Proxy
    After=syslog.target
    After=network.target
    After=mysql.service
    After=mysqld.service
    After=mariadb.service
    After=postgresql.service
    After=pgbouncer.service
    After=postgresql-9.4.service
    After=postgresql-9.5.service
    After=postgresql-9.6.service
    After=postgresql-10.service
    After=postgresql-11.service
    After=postgresql-12.service
    After=postgresql-13.service
    After=postgresql-14.service
    [Service]
    Environment="CONFFILE=/etc/zabbix/zabbix_proxy.conf"
    EnvironmentFile=-/etc/sysconfig/zabbix-proxy
    Type=forking
    Restart=on-failure
    PIDFile=/run/zabbix/zabbix_proxy.pid
    KillMode=control-group
    ExecStop=/bin/kill -SIGTERM $MAINPID
    RestartSec=10s
    TimeoutSec=0
    [Install]
    WantedBy=multi-user.target​
    Contents of /run/zabbix
    total 4.0K
    -rw-rw-r-- 1 zabbix zabbix 4 Feb 16 13:17 zabbix_agentd.pid
    srwx------ 1 zabbix zabbix 0 Feb 16 13:17 zabbix_proxy_rtc.sock
    srwx------ 1 zabbix zabbix 0 Feb 16 13:18 zabbix_proxy_preprocessing.sock
    srwx------ 1 zabbix zabbix 0 Feb 16 13:18 zabbix_proxy_availability.sock​
