Zabbix trapper value is not received if item is created directly on host
  • pzn
    • Feb 2023
    Using Zabbix 6.0.13
    Steps to reproduce:
    • run a shell script which executes every 10 seconds: zabbix_sender -z 127.0.0.1 -s tryhost -k trykey -o 12345
    • create host "tryhost"
    • inside the host config, create item "tryitem" type "Zabbix trapper" key "trykey" number(unsigned)
    • wait a minute. You will notice that no data appears in "latest data"
    • I think the steps above should work, however they don't
    • delete the created item
    • create a new template "trytemplate", inside the template create item "tryitem" type "Zabbix trapper" key "trykey" number(unsigned)
    • edit the host and link it to the template "trytemplate"
    • wait a minute. Now data appears in "latest data"
    Am I doing something wrong? Should items always be inside templates? I notice this only for "Zabbix trapper" type. I'm a Zabbix newbie, sorry for any misunderstanding in reading the docs :-)
    Thanks,
    Pedro
  • tim.mooney
    • Dec 2012
    • 1434
    No, items can be one-offs, they are not required to be part of a template.
    Is this happening because of the warning in the docs about about waiting 60 seconds after creating the item before sending any data? https://www.zabbix.com/documentation...mtypes/trapper
    • pzn
      • Feb 2023
      Thanks Tim, you got right to the point! I tested it again with a wait time >60s and all was OK. I missed that "60 seconds warning". Sorry for the "RTFM" miss.
