Zabbix Trigger prototype not working
  • Mitchell-Zabbix
    • Feb 2023
    • 10
    Hi everyone
    I'm a newbie to Zabbix and can't figure this out.
    Zabbix server version: 6.0.13
    Zabbix agent version: Zabbix agent 2 - 6.2.7
    Template: Windows by Zabbix agent (built in template)
    Discovery rule: Mounted filesystem discovery
    Trigger prototypes that are not firing:
    Click image for larger version  Name:	image.png Views:	13 Size:	64.7 KB ID:	459837
    At the host level, latest data, the discovery seems to be working because it found all attached drives and shows the utilization.
    Click image for larger version  Name:	image.png Views:	4 Size:	2.8 KB ID:	459838
    As you can see it is above 95%, so it should fire?
    Image below are the macro's attached to the template.
    Click image for larger version  Name:	image.png Views:	4 Size:	3.9 KB ID:	459839
    Thanks in advance!
    Edit 1:
    I have changed the macro's to 80 for the warning and 85 for crit.
    The warning does seem to fire for the E: drive but not for F:
    • 5004
    As you see that trigger contains multiple items, also "total - used " and timeleft() based on 1h data... let it run a bit.. it may not have enough data yet...
