zabbix agent won't start after changing configuration file
  • deiv23
    • May 2016
    I have zabbix server on debian, and I'm trying to configure zabbix agent 3.0.0 on a windows machine using the msi installer
    Everything seems to work ok, the service is running, I have disabled the firewall on windows to test if I can connect via telnet on port 10050 to the agent on my windows machine. I couldn't so I checked the configuration file to see if I was missing something.
    I saw the properties ListenPort and ListenIP, filled it with the server ip and port 10050. But now after stopping the service, it can't be started again showing this error:
    "Error 1067. El proceso ha terminado de forma inesperada"
    If I comment again those properties, the server can be started again.
    Do I need to use those params in order to connect to the agent via telnet? if so, how can I change them and start the service?
    Thanks.
  • deiv23
    • May 2016
    error message
    The error message I'm getting in the log when I fill ListenIP parameter is:
    listener failed: bind() for [[212.71.237.200]:10050] failed: [0x00002741] The requested address is not valid in its context.
    • deiv23
      • May 2016
      source of the problem was another
      I had no need to configure the listenIP parameter.
      Just needed to redirect the incoming packets on port 10050 to my local machine in the router NAT.
