i have an old SQL server that i want to monitor with the template MSSQL by ODBC.
I have zabbix 6.2 on ubuntu 20.04
installed odbc driver sql 18
configure odbc.ini
test connection with isql : success
configure macro in the template (instance, login, password, DSN)
the template work great and get lot's of info on the sql server, but quand get some item, like : mssql: get job status, mssql: get las backup
unfortunately that' the info i need.
the error on this item is an SSL routine error
i have reboot the zabbix server, but no change.
I suspect it's a TLS 1.0 problem, i have another sql server that is under a newer TLS and it's working fine.
i have made modification in the openssl.cnf file : minprotocol = TLSv1 et cipherString = DEFAULT@SECLEVEL=0
Thanks for your help !
configure odbc.ini
