Problem resolved notification takes 30 minutes
  • ssks393
    • Feb 2023
    • 28
    can anybody tell why after the problem is resolved zabbix detects it after 30 minutes?
    • 4996
    Check intervals, Trigger expressions... These can easily influence the resolution times...
    • ssks393
      • Feb 2023
      • 28
      item update interval is 5 seconds, triger expression is in the screenshot
        • 4996
        If you ping your hosts in every 5 sec and you have many of those, your server is really busy accepting all that data.. Could also lead to late resolutions...
        In my mind anything below 1m is overkill.. and even 1m usually is too often..
