Using user macros inside keys (on discovery rule)
  • i5513
    • Nov 2011
    • 12
    [ PLEASE IGNORE THIS POST , it was caused by my browser cache , it was displaying the error caused by a erroneus key ]
    [ keys with macros works fine ]
    I tried to find any solution o any bug, but I did not find.
    Imagine you have a tomcat host, with user macros:
    host.tomcat1 {$HTTP_PORT} == 8080
    and you have a user parameter script (get_url) which return urls when you pass the port as parameter:
    { "data": [
    "{#URL}": "/mycontext1",
    "{#URL}": "/mycontext2"
    Creating a new discover rule with key:
    get_url[{$HTTP_PORT}]
    will fail because it contains "$"
    Why user macros cannot be used inside discover rule key ?
    Maybe user parameters could access to host macro defined though environment variables or similar hack. If there is a way, it is not document, I would like to ask you before I open a wishlist issue on zabbix support
    Thank you very much
