How can get specific item in json path
  • bab
    • Aug 2020
    • 197
    I am using the json path. According to the following pic it is working and returns Total_GB
    but I need it to return FREE_GB . I know I should change json path . Would you please say how I can correct it to return FREE_GB instead of TOTAL_GB ? because I resided FREE_GB instead of TOTAL_GB in the json path but it does not work
    This is my json path :
    $.[?(@.NAME=="{#NAME}")].TOTAL_GB.first()
    and this is my item returns :
    [{"NAME":"CRS","TOTAL_GB":"20","USED_GB":"1","FR EE_ GB":"19"},{"NAME":"DATA","TOTAL_GB":"13500","USE D_ GB":"9219","FREE_GB":"4281"},{"NAME":"FRA","TOTA L_ GB":"6000","USED_GB":"66","FREE_GB":"5934"},{"NA ME ":"MGMT","TOTAL_GB":"250","USED_GB":"95","FREE _GB" :"155"},{"NAME":"REDO","TOTAL_GB":"16","USED_GB ":" 0","FREE_GB":"16"}]
    • 4996
    Works in my computer... And should work for you also.. There is no difference, what field you choose to output, TOTAL_GB or FREE_GB or USED_GB...
    If you say " it does not work"... then show us please, how exactly it does not work... whats error or something....
    • bab
      • Aug 2020
      • 197
      It was my mistake . So thanks.
