extract two string log file
  • lib95
    • Feb 2013
    • 21
    I search to extract the lines containing two string <Begin_DateTime> and <End_Datetime> and RC 0 or 1 from a logfile.
    How is it possible to do it ?
    Thank you
    Best regards
    lib95
    • 4996
    That's 4 things you want to find from the log, based on my counting....
    But making all of them match .. https://regex101.com/r/jQvDQ1/1
    • lib95
      • Feb 2013
      • 21
      Thank you, I will try .* <(Begin|End)_Date[Tt]ime> .*RC (\d) on logrt
      Best regards
      • lib95
        • Feb 2013
        • 21
        Ok thank you but doesn't resolve my issue
        I have created two items logs for get Start and End data, but items are empty
        log[/logmsg,,"*Start : [(a-zA-Z0-9+)]"]
        log[/logmsg,,"*End [RC*] : [(a-zA-Z0-9+)]"]
        Best regards​
          • 4996
          So fix it... that's about all I can say based on the info that you provided...
          None of your regexes match anything in your initial examples... Those might be bogus, but you should provide some real examples to expect any help. Show us the item config, provide some examples etc.. We are no miracle workers...
          • lib95
            • Feb 2013
            • 21
            Thank you, my question was not clear, sorry, on the log file, I try to get the last entries like below :
            2023-03-03 02:10:13 Log : ############### END [RC= 0] : 2023-03-02 19:02:59 ################################
            2023-03-03 02:10:13 Log : ############### START : 2023-03-03 02:10:13 ########################################​
            Best regards
              • 4996
              First regex "*Start : [(a-zA-Z0-9+)]"...
              1. you cannot start regex with a multiplier... because it has no preceding tokens...
              2. your pattern is START not Start...
              your regex might be simply ".* START : .*"
              Second regex: "*End [RC*] : [(a-zA-Z0-9+)]"...
              1. again .. do not start with quantifier...
              2. again ... END vs End....
              3. [] in regex has special meaning... so if you want to search for [] literally, you need to escape them ..
              your regex might be ".*END \[RC=.*\] : .*"
              Please bookmark https://regex101.com/ and use it to test your regexes. It will explain in details, how everything is matched...
              • lib95
                • Feb 2013
                • 21
                Thank you
                regards
