Zabbix Console Error
  • nottmforest
    • Mar 2023
    Hi everyone,
    I've linked my Zabbix Console to a list of Windows agents, but some of them give me this error "Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer".
    I've already checked firewall rules and they are all done, as well as checked that the port that I need is opened in Windows Defender. With a telnet from the server to the agent this is the result:
    Otherwise, the telnet tried from the agent to the server does not work.
    Can you help to locate the error?
    Thanks in advice.
