Zabbix Agent 2 v6.4.0 - TLS write fatal alert "decode error"
  • stavros-k
    • Mar 2023
    After upgrading both server and agents to 6.4.0 today, my server logs are spammed with:
    failed to accept an incoming connection: from AGENT IP: unspecified certificate verification error: TLS handshake set result code to 1: file ../ssl/record/rec_layer_s3.c line 308 func ssl3_read_n: error:0A000126:SSL routines::unexpected eof while reading: TLS write fatal alert "decode error"
    All agents are in active mode and use PSK.
    Reverting only agents back to 6.2.7, log spam stops.
    Agent logs show:
    2023-03-12 16:08:55 1678630135 "2023/03/12 15:08:53.857772 [101] active check configuration update from [ZABBIX_SERVER:10052] is working again"
    2023-03-12 16:08:38 1678630118 "2023/03/12 15:08:37.812843 [101] sending of heartbeat message for [AGENT NAME] started to fail"
    2023-03-12 16:08:38 1678630118 "2023/03/12 15:08:37.812333 [101] cannot connect to [ZABBIX_SERVER:10052]: read tcp 192.168.11.150:63308->ZABBIX_SERVER_IP:10052: i/o timeout"
    2023-03-12 16:07:34 1678630054 "2023/03/12 15:07:33.804836 [101] sending of heartbeat message for [AGENT NAME] started to fail"​
    I'm fairly new to Zabbix world and not sure where to start troubleshooting this.
  • JeffNL
    • Mar 2020
    • 17
    I’m following this topic, because I have possibly the same issue.
    Zabbix Agents are intermittent not connected. 15 minutes connected, then 15 minutes not connected, etc.
    Also using PSK.
    Only the servers containing Zabbix Agent and using PSK are having this problem.
    The problem appeared since those servers have been updated, linux updates.
    These servers are running Debian and Ubuntu.
    The Zabbix Agent is used in passive mode (default).
    UPDATE:
    In the last days an extra Zabbix Agent was reconfigured to use PSK.
    In the Agent log file this was seen:
    failed to accept an incoming connection: from x.x.x.x: TLS handshake set result code to 1: file ../ssl/statem/extensions.c line 1618: error:141FA0FD:SSL routines:tls_psk_do_binder:binder does not verify: TLS write fatal alert "illegal parameter"
    Then I also read this topic:
    https://www.zabbix.com/forum/zabbix-...egal-parameter
    Long story short:
    We now will use a unique TLSPSKIdentity value for every connection that needs encryption.
    The problem we were having is solved now.
    • stavros-k
      • Mar 2023
      That's not possible for me. It's more than 600 hosts that are auto registered with the same identity/PSK
      • rhvitfeldt
        • May 2024
        I have the same problem. Do TLSPSKIdentity really have to be unique on all hosts?
        • tim.mooney
          • Dec 2012
          • 1436
          Check out the second "Attention" box.
          • rhvitfeldt
            • May 2024
            I've read it and it's not very clear I think.
            Do I understand it correctly that Identity and PSK value can be identical on all hosts. As long as there's not hosts with same PSK identity and different values?
              • 4996
              Yes. it can be identical on all hosts. Do not use same identity with different value.
              • rhvitfeldt
                • May 2024
                Ok I have the same issue as OP and changing PSK Identity to another that's not used doesn't make a difference. Really strange problem...
                • z0nk
                  • Oct 2024
                  • 45
                  I have same problem, any working solution? I have everywhere same PSK (TLSPSKIdentity and TLSPSKFile content) for autoregistration and after some time each host cant comunicate with error
                  unspecified certificate verification error: TLS handshake set result code to 1: file ../ssl/record/rec_layer_s3.c line 316 func ssl3_read_n: error:0A000126:SSL routines::unexpected eof while reading: TLS write fatal alert "decode error"
                  it is not possible to generate each PSK for zabbix agent in zabbix gui.
                  How fix this problem?
                  All agents are active.
                  Is this correct solution, to have unique TLSPSKIdentity? and same TLSPSKFile file content?
                  EDIT: When I changed it I have error anyway:
                  cannot find requested PSK identity "XYZ"
                  It is not possible to declare more PSK identity in Zabbix Server, especially in auto configuration. How solve this issue? All agents are active.
