Help me monitoring PostgreSQL on Windows Server
  • nguyenhuy100495
    • Feb 2023
    • 10
    I have Windows Server 2012 install PostgreSQL, Zabbix agent 2 and I did steps below:
    Create PostgreSQL user to monitor and inherit permissions from the default role pg_monitor:
    CREATE USER zbx_monitor WITH PASSWORD '123456a@A' INHERIT;
    GRANT pg_monitor TO zbx_monitor;
    Edit pg_hba.conf to allow connections from Zabbix agent (C:\Program Files\PostgreSQL\<version>\data\pg_hba.conf):
    Add these lines to the end:
    host all zbx_monitor localhost md5
    From my Zabbix Server (Ubuntu 20.04 LTS), I added the host and modify macro {$PG.URI}​=tcp://myserverip:5432 {$PG.USER}​=zbx_monitor {$PG.PASSWORD} = 123456a@A
    However I still can not get the monitoring success, the result is "Unknown metric pgsql.ping"
    Anyone please help me, is there any lack of setting?
    • 5004
    What version of agent? Since 6.0.10 (and whatever 6.x version appeared at same time) this plugin is not "built-in" but loadable.
    If you add config to agent to actually load that plugin, it might work...
    • nguyenhuy100495
      • Feb 2023
      • 10
      https://www.zabbix.com/documentation...lugin-loadable
      My Zabbix Server version is Zabbix 6.0.1. © 2001–2022, Zabbix SIA.
      What should I do, please guide me please!
      Thanks so much!​
      • nguyenhuy100495
        • Feb 2023
        • 10
        My Zabbix Agent version is 6.0.14.2400
          • 5004
          Follow the links I posted... plugin configuration. I am not going to write down step-by-step things here, if you can read it from docs...
          • nguyenhuy100495
            • Feb 2023
            • 10
            Sorry for my many questions, but I read the links and difficult to understand how to do.
            Do I need download this plugin source on my Windows Server?
            The guide show that need to modify something on plugin configuration file postgresql.conf, but I don't know where it is?
            Please tell me briefly the steps to do it, thank you!​
            • MaterazziSan
              • Feb 2023
              • 18
              I think this guide is useful https://blog.zabbix.com/setting-up-z...t-works/13208/
              Best regards
              • pscs
                • Feb 2012
                I know this is a bit late, but I had the same problem. And encountered the normal responses not actually answering the question, but assuming that the person having trouble hasn't read the documentation and then posting links to irrelevant articles.
                The problem is that the Windows Zabbix Agent 2 plugins are not built into the agent any longer, and they are not obviously available for download yet in a compiled form (as far as I can see), so it's not a case of not configuring the agent correctly, it's a case of not being able to get hold of the PostgreSQL plugin at all. The only 'official' way to get the plugin for Windows is to download the source and build it yourself.
                This bugtracker issue has links to various versions of the compiled plugin towards the end of the list
