monitore multiple logs in directory
  • lib95
    • Feb 2013
    • 21
    I try to monitore multiple logs in directory :
    logrt["/backup/backup-(Mon|Tues|Wed|Thu|Fri|Sat|Sun).log-[0-9]",".* (bpstart|bpend) .* (\d)"]
    exemple of log file :
    /backup/backup_Sat.log-20230312
    But item is empty, no error.
    How to modify this item log ?
    Thank you
    Regards
    • 4972
    Is only one logfile being written to each day?
    This item is meant to monitor ONE logfile. if multiple one match the regex, then the one what has been modified LAST will be looked at.
    • lib95
      • Feb 2013
      • 21
      Exactly one logfile being written to each day.
      Thank you
      • Hamardaban
        • May 2019
        • 2714
        You have an error in the expression and you can write a little differently
        ^backup_(Mon|Tues|Wed|Thu|Fri|Sat|Sun)\.log-\d+$
        • lib95
          • Feb 2013
          • 21
          I have modified item like below, it's always empty :
          logrt["/backup/^backup-(Mon|Tues|Wed|Thu|Fri|Sat|Sun)\.log-\d+$",".* (bpstart|bpend) .* (\d)"]
          There is a log backup-Thu.log-20230316
          In Zabbix log with debuglevel 5 :
          2023/03/16 15:24:42.297185 [101] created exporter task for plugin 'Log' itemid:1349591 key 'logrt["/backup/^backup-(Mon|Tue|Wed|Thu|Fri|Sat|Sun)\.log-\d+$",".* (bpstart|bpend) .*"]'
          ​Best regards
          • Hamardaban
            • May 2019
            • 2714
            Then you need to look at the contents of the file - which lines exactly do you want to catch?
            • lib95
              • Feb 2013
              • 21
              I want to catch two lines that contains bpstart or bpend.
              Thank you
              regards
              • Hamardaban
                • May 2019
                • 2714
                Then it's unnecessary
                ".* (bpstart|bpend) .*_(\d)"
                And remove the extra spaces. If they are needed, use \s
                • lib95
                  • Feb 2013
                  • 21
                  I have modified the item that is always empty :
                  logrt["/backup/^backup-(Mon|Tues|Wed|Thu|Fri|Sat|Sun)\.log-\d+$",".*(bpstart|bpend).*_(\d)"]
                  In Zabbix log file :
                  2023/03/16 19:55:55.375570 [101] adding new request for key: 'logrt["/backup/^backup-(Mon|Tue|Wed|Thu|Fri|Sat|Sun)\.log-\d+$",".* (bpstart|bpend) .*_(\d)"]'
                  Best regards
                  • MaterazziSan
                    • Feb 2023
                    • 18
                    Best regards
                    Could you write complete 2 lines in log file to be matched?
                    Best regards
                    • lib95
                      • Feb 2013
                      • 21
                      There is only below line :
                      Thank you
                      regards
                      • Hamardaban
                        Hamardaban commented
                        You were asked to write \ show lines from the source log file in which you are looking for matches.
                        It's not about the zabbix log!
                      • 4972
                      This is not a valid regex... you cannot use ^ in the middle of regex...
                      • Hamardaban
                        • May 2019
                        • 2714
                        As far as I understand, the first parameter in the key "consists" of 2 parts: the path to the file and a regular expression describing the file.
                        Here is a quote from the documentation:
                        file regexp - the absolute path to file and the file name described by a regular expression. Note that only the file name is a regular expression.​
                        Based on this, the ^ sign is not in the middle of the regular
                        Moreover, I have items in which this pattern works!
                          • 4972
                          Right... there is some internal processing to achieve that... I tried at regex101 just in case and it did not work out.. Did not think straight, I guess... its Friday after all.
                          Then lets wait until real examples of loglines ..
                          • Hamardaban
                            indeed Friday ! :-)
                        • lib95
                          • Feb 2013
                          • 21
                          #15
                          Example /backup/backup_Sat.log-20230312 :
                          Tue 14 Mar 02:10:31 CET 2023. | INFOS : | IN -> bpstart_notify.policy_my. Debut Sauvegarde.
                          4/B1000028
                          Tue 14 Mar 02:11:10 CET 2023. | INFOS : | OUT -> bpend_notify.policy_my. Fin Sauvegarde.
                          Thank you
                          Regards
