No timestamp parsing with external scripts?
  • jbcheck
    • May 2022
    • 15
    Hi there,
    another question from a rather old man in Germany:
    I'm reading the system log of my fritz!box with a bash sript in externalscripts. This works fine so far, Zabbix receives the data via stdout.
    To get the local timestamp I specified the appropriate log time format. Unfortunately the timestamp will not be parsed.
    What I have tried so far:
    01.04.23 22:33:44 ... --> ddMMyy hh:mm:ss
    2023-04-01 22:33:44 ... --> yyyy-MM-dd hh:mm:ss
    20230401:223344 ... --> yyyyMMdd:hhmmss
    Typ of information is configured as 'Log'.
    A layer 8 problem?
    Thanks in advance!
    jbcheck
  • Hamardaban
    • May 2019
    • 2714
    01.04.23 22:33:44 ... --> dd.MM.yyphh:mm:ss
    2023-04-01 22:33:44 ... --> yyyy-MM-ddphh:mm:ss
    20230401:223344 ... --> yyyyMMdd:hhmmss​
    There is an inaccuracy in the first example.
    And it might be worth replacing spaces with "p​"
    • jbcheck
      • May 2022
      • 15
      Thanks for the quick response!
      I tried it right away and it doesn't changed the output. 'p' as a placeholder for '-' and ':' doesn't change anything either.
      Debug mode says 'timestamp -> 0'. Unfortunately I've no idea if this has something to do with my 'mistery'.
      Ciao for now
      jbcheck
      • Hamardaban
        • May 2019
        • 2714
        What type is your item?
        Show a few lines that you are sending to the server exactly as they are.
        • jbcheck
          • May 2022
          • 15
          Type: External check
          Key: fritzbox-syslog.sh
          Type of information: Log
          Raw data look like this:
          2023-03-16 19:37:20 {"mq_log":[["16.03.23 19:37:18 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222.","504","1","0"],["16.03.23 19:36:44 Anmeldung an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.84.","500","1","0"],["16.03.23 19:36:18 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222. [3 Meldungen seit 16.03.23 19:34:18]","504","1","0"],["16.03.23 19:34:05 Die Systemzeit wurde erfolgreich aktualisiert von Zeitserver xxx.xxx.32.33.","2104","1","0"],["16.03.23 19:34:05 Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: xxx.xxx.192.225, DNS-Server: xxx.xxx.148.70 und xxx.xxx.150.115, Gateway: xxx.xxx.244.211, Breitband-PoP: xxx","24","2","0"],["16.03.23 19:34:01 DSL ist verfügbar (DSL-Synchronisierung besteht mit 63671\/12736 kbit\/s).","11","2","0"],["16.03.23 19:33:18 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222.","504","1","0"],["16.03.23 19:32:52 DSL-Synchronisierung beginnt (Training).","12","2","0"]]}
          Processed (some sed commands) data look like this:
          2023-03-16 19:39:18 2023-03-16 19:39:17 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222. [3 Meldungen seit 16.03.23 19:37:18],504,1,0
          2023-03-16 19:36:44 Anmeldung an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.84.,500,1,0
          2023-03-16 19:36:18 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222. [3 Meldungen seit 16.03.23 19:34:18],504,1,0
          2023-03-16 19:34:05 Die Systemzeit wurde erfolgreich aktualisiert von Zeitserver xxx.xxx.32.33.,2104,1,0
          2023-03-16 19:34:06 Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: xxx.xxx.192.225, DNS-Server: xxx.xxx.148.70 und xxx.xxx.150.115, Gateway: xxx.xxx.244.211, Breitband-PoP: xxx,24,2,0
          2023-03-16 19:34:02 DSL ist verfügbar (DSL-Synchronisierung besteht mit 63671\/12736 kbit\/s).,11,2,0
          2023-03-16 19:33:19 Anmeldung des Benutzers zabbix an der FRITZ!Box-Benutzeroberfläche von IP-Adresse 192.168.1.222.,504,1,0
          2023-03-16 19:32:53 DSL-Synchronisierung beginnt (Training).,12,2,0
          Is a special data format needed perhaps?
          • Hamardaban
            • May 2019
            • 2714
            I think that in order to selection the timestamp and its normal processing, it is necessary that the item receives values in the form of a single line at the beginning of which the time is written.
            Before any processing in the item.
            PS
            I asked about what data the item receives.
            I'm sorry, but I didn't understand that from your answer.
            • jbcheck
              • May 2022
              • 15
              Please excuse the misunderstanding I'm rather old an German. ;-)
              Some more light in the darkness, I hope:
              The only way to get the system log from my router appliance is to query it via TR-064.
              My script queries the whole system log (no other way to get the information) and passes it via stdout.
              What can be seen above (right column) are once the raw data and once the prepared data, as passed exactly.
              The left column shows the zabbix server timestamp. The 'local time' is currently missing / not processed (My understanding which might ge wrong?).
              What data: appliance start and stop messagen, logon, LAN / WAN connection status, DHCP messages, bla
              Is it bad to pass more than one line to the server per script call?
              I'm confused.
              Thanks a lot!
              jb​
                • 5004
                That timestamp thing works, if your raw data is just one line of text like
                If you send in json, then that does not match that... Even if you do some preprocessing to that json, you do not end up with single line starting with a timestamp, but as you showed ... you have item value as
                preprocessing does not split it up into multiple values, which would look like single lines...
                • Hamardaban
                  • May 2019
                  • 2714
                  That's what I've been trying to figure out and explain!
                  • jbcheck
                    • May 2022
                    • 15
                    Ah, I learn and understand. Thank you!
                    So I tried to make things simple and wrote a very small (external) script:
                    echo "2023/03/17 15:53:18 dummy entry"
                    And it seems that I'm still wrong in my assumption of how it works:
                    Timestamp: / Local time (empty): / Value:
                    2023-03-17 19:07:18 2023/03/17 15:53:18 dummy entry
                    Log time format: yyyypMMpddphhpmmpss
                    Should this work or am I completely wrong?
                    • jbcheck
                      • May 2022
                      • 15
                      I gave it another try with jsonpath:
                      In this case, should the date appear in 'local time'?
                      Ciao for now
                      jb
                      • jbcheck
                        • May 2022
                        • 15
                        Could it be that parsing the event date from log is not supported for external checks?
                        Even if I just let the script output the date (with and without time), it doesn't seem to be evaluated. I even tried the same format as in the example.
                        Is there another way to evaluate the log? It doesn't have to be as perfect as with the Zabbix Agent.
                        Thank your very much and a great time!
                        jb​
                        • Hamardaban
                          Hamardaban commented
                          Yes - it looks like it is. "localtime" is guaranteed to work for the log and eventlog keys.
                          I also tried several options and was surprised.
                        • 5004
                        How the value arrives should not matter. I tested with a trapper item.. works as intended...
                        Click image for larger version  Name:	image.png Views:	0 Size:	16.3 KB ID:	461352
                        and then sent value to it..
                        echo ""<hostname>" logitem "2023/03/17 15:53:18 dummy entry"" | zabbix_sender -c /path/to/agent2.conf -i -
                        Click image for larger version  Name:	image.png Views:	0 Size:	4.7 KB ID:	461353​​
                        • Hamardaban
                          • May 2019
                          • 2714
                          I'm sorry - I tried my tests in the morning - and everything works!
                          Mysticism.......
                          Checked "Userparameter", "external checks" and "zabbix trapper" - "Local time" is present.​
                          zabbix_server + zabbix_proxy 6.2.7
                          • jbcheck
                            • May 2022
                            • 15
                            #15
                            Hm, this is myterious indeed.
                            Click image for larger version  Name:	grafik.png Views:	0 Size:	25.6 KB ID:	461835​
                            Click image for larger version  Name:	grafik.png Views:	0 Size:	7.8 KB ID:	461836
                            The output part of my script:
                            curl -s "http://192.168.1.1/query.lua?mq_log=logger:status/log&sid=${sid}" | sed -e "s/\]\,\[/\n/g" | sed -e "s/\]\]\}//g" | sed "s/[^\[\[]*\[\[//" | sed "s/"//g" | sed -e "s/^\([0-9]\{2\}\).\([0-9]\{2\}\).\([0-9]\{2\}\)\(.*\)$/20\3\-\2\-\1\4/g" | sed '1!G;h;$!d' 2>&1​
                            What this line does:
                            - Fetch the log
                            - Insert line breaks
                            - Adjust the date format
                            - Reverse the line order​
                            And if I try something really simple in my script:
                            echo "2023-03-22 21:40:44 bla bla blub"
                            I get this:
                            Click image for larger version  Name:	grafik.png Views:	0 Size:	2.7 KB ID:	461837​
                            That drives my crazy. Currently.
                            So if I wirte the output into a file on my zabbix server (Raspberry Pi 3, Zabbix 6.4.0) and process this file with log / logrt I also get a local time stamp.
                            I'm working on a solution with this ...
                            Thanks and ciao for now
                            jb
