Zabbix Azure Integration Log size issue
  • jc-sm
    • Mar 2023
    Hey Everyone,
    I just created a new Zabbix 6.4 install and have been trying to use the official Azure integration found here. The problem I am having is that every once in a while I stop receiving data from Azure on all my VMs and the "Azure: Get Errors" items show the following error: "Failed to receive data: auth : Error: log exceeds the maximum size of 8388608 bytes.​"
    To attempt a fix, I have done the following:
    /etc/zabbix/apache.conf
    php_value memory_limit 512M
    php_value post_max_size 16M
    /etc/php/8.1/apache2/php.ini ​​
    post_max_size = 16M
    upload_max_file_size = 200M
    Not sure what other settings could be putting an upper limit on my logging.
    Has anyone had a similar issue?
    JC
    • 4996
    That may be error from Azure and have nothing to do with Zabbix config.
    • jc-sm
      • Mar 2023
      I tried looking for Azure errors originally but everything seems to point at PHP or Apache limits unfortunately.
      • ryanb33
        • Mar 2023
        I came across this error recently and it's a Zabbix memory limit that is hardcoded
        • ryanb33
          • Mar 2023
          Here is a post with more details: https://support.zabbix.com/si/jira.i...ZBX-22492.html
          • jc-sm
            jc-sm commented
            That kinda sucks but I appreciate it. I may just have to go the agent route on those.
