Upgrade from 6.2.3 to 6.4.0 on Debian failed. After upgraded all packages.
  • GerryBass
    • Oct 2022
    HiHello everyone,
    I just upgrade from 6.2.3 to 6.4.0 this morning and at the end ...
    I got:
    The Zabbix database version does not match current requirements. Your database version: 6020000. Required version: 6040000.
    I reviewed all step and at the end I checked the actual version.
    root@cpopapzab01:~# apt list --installed | grep zabbix
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    zabbix-agent/unknown,now 1:6.4.0-1+debian11 amd64 [installed]
    zabbix-apache-conf/now 1:6.2.3-1+debian11 all [installed,upgradable to: 1:6.4.0-1+debian11]
    zabbix-frontend-php/unknown,now 1:6.4.0-1+debian11 all [installed]
    zabbix-release/unknown,now 1:6.4-1+debian11 all [installed]
    zabbix-sender/now 1:6.2.3-1+debian11 amd64 [installed,upgradable to: 1:6.4.0-1+debian11]
    zabbix-server-mysql/unknown,now 1:6.4.0-1+debian11 amd64 [installed]
    zabbix-sql-scripts/now 1:6.2.3-1+debian11 all [installed,upgradable to: 1:6.4.0-1+debian11]
    root@cpopapzab01:~#​
    The upgrade process did not worked properly
    apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    I re-installed the failed one individually like this
    apt-get install --only-upgrade zabbix-frontend-php
    apt-get install --only-upgrade zabbix-apache-conf
    apt-get install --only-upgrade zabbix-sender​
    Now I have this:
    zabbix-apache-conf/unknown,now 1:6.4.0-1+debian11 all [installed]
    zabbix-sender/unknown,now 1:6.4.0-1+debian11 amd64 [installed]
    zabbix-sql-scripts/unknown,now 1:6.4.0-1+debian11 all [installed]
    root@cpopapzab01:~#
    Reboot Zabbix server, .. clear browser cash, etc ...
    I still have the same message !!!
    Database error
    • The Zabbix database version does not match current requirements. Your database version: 6020000. Required version: 6040000. Please contact your system administrator.
    ​Someone can help me ? There is a way to fix this ? "This server is virtual, so I did a reverse snapshot to restore it. It's a POC server for a proposed monitoring system."
    Thanks a lot.​​
  • Answer selected by tim.mooney at 19-03-2023, 01:38.
    GerryBass
    • Oct 2022
    Hi Mr.Mooney
    For the required, I'm ok.
    Need MariaDB version 10.5.00-10.10.X, I have 10.5.18-MariaDB-0+deb11u1
    The minimum required libssh version has been raised from 0.6.0 to 0.9.0 I have Version: 0.9.5-1+deb11u1
    In Logs, I found error.
    Access denied for user 'zabbix'@'localhost' (using password: NO)
    I fixed the situation with this.
    mysql -u root -p
    GRANT ALL PRIVILEGES ON zabbix.* TO 'zabbix'@'localhost' IDENTIFIED BY 'NewPassword';
    FLUSH PRIVILEGES;
    You were right to go check the logs, I didn't think to do it at first. Thank you very much :-)
    All is fine now :-)
    • tim.mooney
      • Dec 2012
      • 1434
      Originally posted by GerryBass
      Now I have this:
      root@cpopapzab01:~#
      All your packages are upgraded finally, which is good. When you restart the zabbix-server service, it should upgrade your MySQL database if it can.
      When database upgrades fail, there is typically a very good clue about what the problem is in the zabbix_server.log file. Have you checked that? What does it say?
      You didn't say what version of MySQL/MariaDB/Percona you're using, but there are special upgrade instructions for those databases. Have you read them: https://www.zabbix.com/documentation...rade_notes_640
      • GerryBass
        • Oct 2022
        Hi Mr.Mooney
        mysql -u root -p
        FLUSH PRIVILEGES;
        All is fine now :-)
