Cannot obtain filesystem information: [13] Permission denied
  • rubendob
    • Apr 2012
    • 36
    Hi
    server: 3.0-1+trusty
    agent: zabbix-agent-3.0.2-1.el6.x86_64
    nodes: Centos 6
    uname: Linux ns227962.ovh.net 2.6.32-042stab108.2
    I'm running Zabbix 3 agent on a bunch of hardware nodes with Openvz Centos 6. I'm getting a permission problem to get data from some simfs or ploop devices mounted on the /vz
    9729:20160523:080323.028 item "ns3016949.ip-151-80-103.eu:vfs.fs.size[/vz/root/106,total]" became not supported: Cannot obtain filesystem information: [13] Permission denied
    Do you think I can fix this in some way?
    UPDATE1:
    I've added zabbix as sudoer user as
    zabbix ALL=(ALL)        NOPASSWD: ALL
    then login as zabbix, no success
    Thanks!
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Does it work from command line on agent box:
    df /vz/root/106
    or if you run it using zabbix_agentd:
    zabbix_agentd -t vfs.fs.size[/vz/root/106,total]
    • klm46
      • Mar 2018
      I got the same issue here with actual environment of zabbix.
      zabbix_agentd -t vfs.fs.size[/opt/lvs/share,free]
      vfs.fs.size[/opt/lvs/share,free] [u|39888629760]
      /dev/sdb 50G 9.5G 38G 21% /opt/lvs/share
      At zabbix the error is the same as written here. any ideas?
      • Atsushi
        Atsushi commented
        Please check the access permission of that path.
        Is it accessible by the user who is activating the Zabbix agent?
        If you have enabled SELinux, please make sure the policy setting is done.
        Information that identifies the cause should also be output to various logs.
        Please also check the logs.
    • si458
      • Aug 2018
      did anybody manage to get this issue resolved?
      im having the same issue...
      Virtuozzo 7 Machine being monitored by zabbix-agent
      [root@vz1 ~]# zabbix_agentd -t vfs.fs.size[/vz/root/0cefcef2-567b-4517-9024-f0591eff310f,free]
      vfs.fs.size[/vz/root/0cefcef2-567b-4517-9024-f0591eff310f,free] [u|34178330624]
      running command from the machine gets and returns results, but zabbix panel is still showing
      • Dearli
        • Mar 2019
        First,ensure that the zabbix user in your system has the right permission,then run the command "systemctl restart zabbix-agent".Now i can see the result what i want!
