Web monitoring but no item created
  • gdseb
    • Mar 2023
    I am beginner on Zabbix 6.2.
    After discovering my hosts and adding templates
    I have created web scenario (with only one step) for check my web site. I would like create trigger but i didn't found any items :
    Example :
    Item key: web.test.fail[Scenario]
    Item key: web.test.in[Scenario,,bps]
    Item key: web.test.error[Scenario]
    Documentation indicates : As soon as a scenario is created, Zabbix automatically adds the following items for monitoring.
    How is it possible ? Missing configuration ? other ...?
    I appreciate your help.
    Regards
    Seb
    • 4996
    These do not show up in your usual "Configuration"-> "host"->"your host item list"
    But when you start to create your trigger and press that "add" button beside "Expression" field, you will see those web items also.​
