Zabbix upgrade issue on Rocky Linux 9
  • fs.geoffk
    • Feb 2023
    I have Zabbix 6.2 sucessfully installed on Rocky 9.
    I followed the upgrade guide for RHEL based systems.
    dnf gives the following error when I try and upgrade
    Problem: cannot install the best update candidate for package zabbix-server-pgsql-6.2.7-release1.el9.x86_64
    - nothing provides libevent-2.1.so.6()(64bit) needed by zabbix-server-pgsql-6.4.0-release1.el8.x86_64
    - nothing provides libevent_pthreads-2.1.so.6()(64bit) needed by zabbix-server-pgsql-6.4.0-release1.el8.x86_64
    - nothing provides libnetsnmp.so.35()(64bit) needed by zabbix-server-pgsql-6.4.0-release1.el8.x86_64
    Does anyone have any suggestions on how to fix this?
  • markfree
    • Apr 2019
    • 875
    You should check your system repositories.
    Mine comes with these enabled by default:
    $ sudo dnf repolist --enabled
    repo id    repo name
    appstream  Rocky Linux 9 - AppStream
    baseos     Rocky Linux 9 - BaseOS
    extras     Rocky Linux 9 - Extras
    • fs.geoffk
      • Feb 2023
      Yep, I needed to update my packages. I have installed dnf-automatic to remind me of this in future!
