Anomaly Detection
  • ngarry1991
    • Jan 2023
    Anomaly Detection
    Hi All,
    I was wondering if anyone could help me with an issue I am having.
    We fairly recently upgraded from version 5 to 6.0.12 LTS and I was hoping to use the trenstl trigger but I am not sure I am using it correctly.
    As background I have an item which calculates figures based on items in our elastic index over the past 24 hours, what I want to do is trigger if this varies from the usually. So say the figures are normally between 110-120 and then it drops to say 90 I would like a trigger.
    I have configured the below:
    HTML Code:
    trendstl(/HOST/KEY,28d:now/d,1d,7d,1,"mad")="(1/24)"​
    From my understanding this should gather data for a 28 day period and flag anomalies based on the current day to the day 1 week previous, however this isn't triggering and reporting ok although the figures the previous week was 115 and today is around 92.
    Am I missing something or is there actually a better way to do this, I don't really want to use absolute figures and would rather use some intelligence. I also looked at bassline triggers but not had much luck with them either.
    Below is an example of the data, I have it on a schedule atm so it doesn't gather data over the weekend as this would by design drop.
    Click image for larger version  Name:	image.png Views:	0 Size:	23.8 KB ID:	461382​
  • markfree
    • Apr 2019
    • 875
    The trendstl function returns an anomaly rate, a decimal value between 0 and 1.
    1/24 = 0,0416666666666667
    Is your function operator correct?
    • ngarry1991
      • Jan 2023
      Hi Mark,
      I was trying to follow the online video's that implied the above formula would trigger in any 1 deviation in the past 24 hours but do think this may be were I am going wrong.
      I have as a work around added a calculated Item that gets a percentage drop from the most recent item and an item 1 week previous that seems to do what I want however I would prefer to use the anomaly detection if you have any pointers?
      Cheers
      • markfree
        • Apr 2019
        • 875
        I take it that your data has some seasonality. So, the way I understand it, your function does:
        Analyzes the last 28 days of trend data, searches for anomalies for the previous 1 day of that period and expects the periodicity to be 7 days.
        The number of deviations to count as anomaly is 1 and it is using the MAD algorithm (default).
        Remember that the resulting value is an anomalies rate
        Does that logic fit your expectations?
        If you were to create a calculated item (trendstl(/HOST/KEY,28d:now/d,1d,7d,1), what results would you get?
        • ngarry1991
          • Jan 2023
          Cheers I never thought to try my calculation as a calculated item so I could never see my output.
          I think now I can play with it and see the figures this helps me.
          Thanks again for all the help/pointers​
