Item patterns do not "catch" all data in graphs
  • comboloid
    • Dec 2022
    • 15
    Hello!!
    We have setup some custom container memory monitoring and grabbing some values over a specific value. The problem is that while the data is properly grabbed from Zabbix:
    They are not displayed in the related graphs we have created. We are using item patterns
  • markfree
    • Apr 2019
    • 875
    Do you mean Graph widget from the Dashboard?
    You may use wildcards to match multiple items. While you are typing the item name/pattern, it is display the possible matchs in the dropdown.
    • comboloid
      • Dec 2022
      • 15
      (for some reason, my initial message was half uploaded)
      Hello mark! Yes i was referring to the graph widget indeed.
      We are monitoring for example (among other things) the containers with the top memory usage. The latest data is the following:
Name:	Screenshot from 2023-03-21 11-35-22.png
      For example we see the one with last value 6.81gb. It's isolated graph is the following:
Name:	Screenshot from 2023-03-21 11-37-16.png
      The metric i am using is container_name.top_memory_usage. I use the wildcard *.top_memory_usage but it only displays some(about half) of them, without specific reason or pattern behind that.
Name:	Screenshot from 2023-03-21 11-38-28.png
