How to set up docker monitoring on Windows 11?
  • nom77
    • Mar 2017
    • 34
    I can't configure the monitoring of the docker, which is on Windows 11,
    zabbix 6.2 is on a virtual machine that I downloaded from the official website
    After installing zabix agent zabbix_agent2-6.2.8-windows-amd64-openssl.msi in windows 11, the zabbix user did not appear, there is no one to give rights to the docker group, and there is a docker group
    On the zabix server, there is a connection with an agent on port 10050, but there are no metrics for docker
    metrics from the default template Docker by Zabbix agent 2 do not go
    if you write on the zabbix server
    zabbix_get -s 192.168.0.89 -k docker.info
    writes
    Unknown metric docker.info​
    I found this entry in the agent logs on windows
    2023/03/23 21:55:13.712409 received passive check request: 'docker.containers' from '192.168.0.15'
    2023/03/23 21:55:13.712409 [1] processing update request (1 requests)
    2023/03/23 21:55:13.712409 [1] registering new client
    2023/03/23 21:55:13.712409 Calling C function "new_global_regexp()"
    2023/03/23 21:55:13.712925 [1] cannot monitor metric "docker.containers": Unknown metric docker.containers
    does this mean the agent is compiled without docker support ?​​​
  • max_bz
    • Mar 2023
    • 17
    Hi
    You need to do some additional things, to monitor Docker containers on Windows
    Firstly:
    Go to the Zabbix official repository on GitHub: https://github.com/zabbix/zabbix-docker.
    Click on the "Scripts" folder.
    Download the following scripts:
    • docker_discovery.ps1
    • docker_info.ps1
    • docker_stats.ps1
    Save them in the C:\Program Files\Zabbix Agent2\scripts on your Windows 11 machine.
    Then modify Zabbix agent configuration file. Add the following lines:
    UserParameter=docker.discovery[*],powershell -ExecutionPolicy Bypass -File "C:\Program Files\Zabbix Agent2\scripts\docker_discovery.ps1" "$1"
    UserParameter=docker.info[*],powershell -ExecutionPolicy Bypass -File "C:\Program Files\Zabbix Agent2\scripts\docker_info.ps1" "$1" "$2"
    UserParameter=docker.stats[*],powershell -ExecutionPolicy Bypass -File "C:\Program Files\Zabbix Agent2\scripts\docker_stats.ps1" "$1" "$2" "$3"
    Save the configuration file and restart the Zabbix agent2 service.​
    After that you should be able to use the following items:
    • docker.discovery: This item will discover all running Docker containers.
    • docker.info: This item will retrieve information about a specific Docker container, such as its name, ID, status, etc.
    • docker.stats: This item will retrieve statistics about a specific Docker container, such as its CPU usage, memory usage, network usage, etc.
    • nom77
      nom77 commented
      I couldn't find the Scripts folder by link https://github.com/zabbix/zabbix-dockers
      docker_info.ps1
      docker_stats.ps1
      these files could not be found even through google.com, maybe there is an error in the name? or give plz an exact link
  • nom77
    • Mar 2017
    • 34
    I found such a file at this link https://github.com/zabbix/zabbix-doc...agent2/windows file docker-entrypoint.ps1​
    maybe that's what you meant?​
    • max_bz
      • Mar 2023
      • 17
      Hm, sorry for miscommunication. Link in not active, some king of old info.
      You can try these scripts. But they were created by me using content found on the Internet.
      • nom77
        • Mar 2017
        • 34
        The information on the zabbix server for the template Doker by Zabbix agent 2 does not appear
        but when i wited
        I see
        "docker inspect" requires at least 1 argument.
        See 'docker inspect --help'.
        Usage: docker inspect [OPTIONS] NAME|ID [NAME|ID...]
        Return low-level information on Docker objects
        "data": {
        "Status": {
        "Ports": {
        "Name": {
        "ID": {
        "Image": {
        • Muhach
          • Jan 2024
          I have the same problem. Have anyone found a good solution?
