Zabbix http poller processes more than 75% busy - How do I resolve this alert?
  • jornell
    • Feb 2023
    • 18
    Hello, Some time ago I got the following alert "Zabbix http poller processes more than 75% busy".
    I have zabbix 6.0 on Ubuntu 20, and I should have plenty of resources for the number of servers that are being monitored,
    If anyone knows what this alert means and how to solve it, I would be very grateful.
  • MaterazziSan
    • Feb 2023
    • 18
    You need to find this section in your zabbix server configuration file (zabbix_server.conf):
    ### Option: StartHTTPPollers
    #    Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    As you can see, "StartHTTPPollers" default value is "1". You can increment it to "2" and restart zabbix service.
    I cannot suggest you to increase it too much in one shot. If "2" is not suffient, increase it a little more. After that, that trigger should be closed.
    Best regards
