Hi all,
I've one proxy setup in a FreeBSD jail (all my other proxys & the Server are on Debian). It worked like that for quite a while but a few days ago it broke...
This is the Config:
I'm using that config (except for FreeBSD paths) with half a dozen Debian based proxys
And this is what the log spits at me:
The file in that path is there and has a recent timestamp:
mirco@mgr ~ $ sudo ls -alh /usr/local/lib/sqlite/zabbix_proxy.db
-rw-r--r-- 1 zabbix wheel 4.2M Mar 21 2022 /usr/local/lib/sqlite/zabbix_proxy.db
I've already double checked the docs about my DB Params but so far that seems to fine for sqlite... Is it possible that the FreeBSD Package changed it's builtin supported DB's in the past?
This is the Config:
Server=myserver.some.domain Hostname=mgr.some.client.lan LogFile=/var/log/zabbix/zabbix_proxy.log LogFileSize=0 DebugLevel=5 PidFile=/var/run/zabbix/zabbix_proxy.pid DBName=/usr/local/lib/sqlite/zabbix_proxy.db ProxyMode=0 ConfigFrequency=120 DataSenderFrequency=60 HeartbeatFrequency=10 TLSConnect=psk TLSAccept=psk TLSPSKFile=/usr/local/etc/zabbix4/zabbix-some-lan.psk TLSPSKIdentity=mgr.some.client.lan Timeout=4 ExternalScripts=/usr/local/lib/zabbix4/externalscripts FpingLocation=/usr/local/sbin/fping Fping6Location=/usr/local/sbin/fping6 LogSlowQueries=300
37674:20230326:071132.855 Web monitoring: YES 37674:20230326:071132.855 VMware monitoring: NO 37674:20230326:071132.855 ODBC: YES 37674:20230326:071132.855 SSH support: NO 37674:20230326:071132.855 IPv6 support: YES 37674:20230326:071132.855 TLS support: YES 37674:20230326:071132.855 ************************** 37674:20230326:071132.855 using configuration file: /usr/local/etc/zabbix5/zabbix_proxy.conf 37674:20230326:071132.855 In zbx_load_modules() 37674:20230326:071132.855 End of zbx_load_modules():SUCCEED 37674:20230326:071132.855 In init_database_cache() 37674:20230326:071132.855 In zbx_mem_create() param:'HistoryCacheSize' size:16777216 37674:20230326:071132.855 valid user addresses: [0x802200168, 0x8031ffff0] total size: 16776840 37674:20230326:071132.855 End of zbx_mem_create() 37674:20230326:071132.855 In zbx_mem_create() param:'HistoryIndexCacheSize' size:4194304 37674:20230326:071132.856 valid user addresses: [0x803200178, 0x8035ffff0] total size: 4193912 37674:20230326:071132.856 End of zbx_mem_create() 37674:20230326:071132.856 End of init_database_cache() 37674:20230326:071132.856 In init_configuration_cache() size:8388608 37674:20230326:071132.856 In zbx_mem_create() param:'CacheSize' size:8388608 37674:20230326:071132.856 valid user addresses: [0x803600168, 0x803dffff0] total size: 8388232 37674:20230326:071132.856 End of zbx_mem_create() 37674:20230326:071132.856 End of init_configuration_cache() 37674:20230326:071132.856 In init_selfmon_collector() 37674:20230326:071132.856 init_selfmon_collector() size:8560 37674:20230326:071132.856 End of init_selfmon_collector() collector:0x801b3d000 37674:20230326:071132.856 In zbx_db_get_database_type() 37674:20230326:071132.856 In DBconnect() flag:0 37674:20230326:071132.859 [Z3001] connection to database '/usr/local/lib/sqlite/zabbix_proxy.db' failed: [2002] Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) 37674:20230326:071132.860 database is down: reconnecting in 10 seconds
