Zabbix 5.4.4 Unable to access WEBUI after reboot
  • simonma
    • Aug 2021
    Hello Forum.
    I restarted my Zabbix server and after the reboot I am unable to access the web ui.
    ERR_CONNECTION_REFUSED
    I suspect it is due to folder/file permissions.
    All services are running.
    Environment:
    os debian 10 buster
    zabbix_server 5.4.4
    zabbix_agentd 5.4.4
    mariadb 10.3.38
    php 7.3.3-1~deb10u3
    nginx 1.14.2
    Can you please suggest what may be causing this?
    When I browse to port 80, the Apache2 landing page is returned.
    When I browse to port 443 (required using self-signed certificate), "This site cant be reached, <ip_address> refused to connect. ERR_CONNECTION_REFUSED" is returned.
    The apache2 service is not running but loaded.
    The nginx service is running.
    The server no longer appears to be listening on port 443, it is listening on port 80.
    Regards,
    Simon
  • simonma
    • Aug 2021
    I discovered the server was no longer listening on port 443 and had dropped its SSL configuration.
